Planning a 120k service
Old Aug 9, 2012 | 12:37 PM
FlyingZebra34's Avatar
Default Planning a 120k service
Ok right now I'm looking to replace the timing chain assembly, the water pump and oil pump. while all of that is open is there anything else I should work on?
Old Aug 9, 2012 | 12:42 PM
drowssap's Avatar
hoses, belt and t-stat thats about it on the front of the motor. There is also the cam shaft sensor, but I dont know if there are really an issue.
Old Aug 9, 2012 | 01:51 PM
Do my major service if it has been 30,000 miles since last done with possibly the exception of the wires, plugs and front drive shaft.
While working on it, check out your motor mounts, viscus clutch and start planning on a radiator over the next 20,000 miles.
Old Aug 9, 2012 | 09:17 PM
And make that an 82 C soft spring stat and treat the truck to an Ultra Gauge. Also consider oil PSI test before and after, or aftermarket oil PSI gauge.
Old Aug 9, 2012 | 10:36 PM
bosshogt's Avatar
Its also a great time to replace the crankshaft seal on the front cover, oil pickup O-ring. Oil filter sump O-ring. All those are reasonably priced at the dealer. There is also an aditional O-ring inside the oil filter sump. If you have any questions I did this job last week. All it pretty straight forward.
Old Aug 10, 2012 | 05:31 AM
X2 on the oil sump renovation. A little loctite on the oil pickup tube bolts after replacing O-ring. Hope your screen looks better than this one...
Attached Thumbnails Planning a 120k service-modp_1011_02_o-ilsac_gf5_motor_oil_standard-sludge_buildup.jpg
Old Aug 10, 2012 | 07:13 PM
do i replace that screen or clean it?
Old Aug 12, 2012 | 11:56 AM
Old Aug 12, 2012 | 01:12 PM
Why not a soft spring t/stat, a Air Tex water pump, much better then OEM? Much better way to go.
Old Aug 12, 2012 | 02:22 PM
Could I get some links? Thank you very much
