Please help
Hello all,
When i started my 04 disco today i noticed engine was idleing ruff. half was down the road 3 amegos came on followed by check engine light.Ultra gauge gave me codes pc1590 and po303.
Thoughts, Thanks
Thoughts, Thanks
1590 is a standard ABS error code that the Ultra Gauge uses. You will need a true ABS scanner to determine the actual codes.
P0303 Cylinder 3 misfire detected Injector 3 excess emissions/catalyst damaging level of misfire
thanks for the reply,i guess 1590 is the amigos, and i will look into cyl3.mabey sparkplug wire,clogged injector.
whurst79
Jan 28, 2013 09:24 PM
Speed racer
Oct 11, 2008 10:56 PM
