Plinking sound in glove box when braking.
Old Jan 15, 2016 | 01:23 PM
jamieb's Avatar
Default Plinking sound in glove box when braking.
When I am coming to a stop, at the exact moment the car actually stops, a sound "plinks" from the glove box area - like a rubber band is being snapped against plastic. Sounds like some kind of vacuum diaphragm or vacuum servo. I have not pulled the box down or off yet to look behind it, inside the cab. Anyone have any idea before I go digging? Only happens when the vehicle comes to a halt.
Old Jan 16, 2016 | 06:49 PM
Best4x4's Avatar
Check to see if the glove box light is broken and hanging down. It "could" make a sound if it's just hanging from the wiring harness.
Old Jan 16, 2016 | 11:36 PM
jamieb's Avatar
Will do. Thanks
Old Jan 19, 2016 | 03:11 PM
jamieb's Avatar
OK, I noticed today while already at a stop the "plink" sound. It may just be a coincidence when braking. Today it happened when I powered off the air vents. I have it set to ECON and adjust the heat up/down accordingly.
is there a flap that could be closing behind the glove box? Also, I notice if I power off the system, it still releases a trickle of hot air into the cabin.
SEMills35
May 6, 2008 10:30 PM
willlane
Mar 3, 2008 07:50 AM
jdelp
Apr 26, 2007 10:21 AM
BuffaloRider
Feb 15, 2007 11:30 PM
spiderfreak80
Mar 16, 2006 03:19 AM
