Pls. Help. My Disco 98 won't start
Old Jul 6, 2008 | 04:58 AM
samoy's Avatar
Default Pls. Help. My Disco 98 won't start
My Disco 98 wouldn't start so I'v justfitted in a new fuel pump into the car but it still won't start. I was thinking since my fuel level shows less than a quarter tank full, that maybe I should fill more fuel???
I was also thinking that maybe the new fuel pump is defective. Is there any way i can test it, maybe with a volt meter??
Old Jul 6, 2008 | 07:36 AM
Default RE: Pls. Help. My Disco 98 won't start
Why did you decide to replace the fuel pump, what tests did you do, is it not building pressure, no power to it, what????
Old Jul 6, 2008 | 10:59 AM
roverguy7's Avatar
is it a no crank, or a cranking no start... does your check engine light go off while cranking... is your security led on solid... generally a shot in the dark is not the way to go, give us some info and youll get the answer you need... on a d1 you have a fuel rail test port, check to see if you have pressure there, if so, fuel pump was not right
Merritt87
Jan 21, 2013 07:26 PM
Ems
Aug 1, 2012 08:22 PM
muckster
Sep 2, 2008 08:45 PM
argoman
Defender
Apr 28, 2007 12:32 PM
Disco Kiwi
Jan 31, 2006 07:13 PM
