Plugs and Wires?
Old Feb 16, 2012 | 04:38 PM
creepin's Avatar
Default Plugs and Wires?
I have searched some but not clear on this........What plugs and wires would you or should you use....Meaning the best....and stay clear from?
In my case:
2004 DII 4.6
Last time they were changed factory Rovers were used.
Old Feb 16, 2012 | 04:41 PM
Any of the better Champion or Bosch plugs will be good. Use only 8 mm silicone wires, my preference are the Magnacor wires.
Old Feb 16, 2012 | 04:48 PM
creepin's Avatar
Hey Mike,can you use bigger than 8mm? or not worth it. How are bosch wires compaired to other?
Old Feb 16, 2012 | 07:40 PM
ebg18t's Avatar
I just used the STi 8mm wires from BP Utah and Bosch +4 plat plugs.
Old Feb 16, 2012 | 10:10 PM
ALAKDisco's Avatar
I just did STI 8mm wires and Bosh +4 plugs today and I couldn't be more pleased. (I also did all four O2 sensors.) The write up in the sticky section is great, I'd read the entire thread before starting, it'll save you some time once you get going.
Old Feb 16, 2012 | 10:17 PM
ALAKDisco's Avatar
Let me also add that I purchased my wires from BP Utah on Mike's recommendation and I'll do as much business as I can with them in the future. Great guys and quick service.
Old Feb 17, 2012 | 08:54 AM
Bigger wires are not necessary and most 8.5 wires are pretty expensive. I would not recommend the Bosch wires, they don't hold up under our engines heat.
Old Feb 17, 2012 | 09:37 AM
creepin's Avatar
Someone today said the samething about the bosch wires....good to know....
I might go with the NGK stuff...
Old Feb 17, 2012 | 11:39 AM
Why????
Go with what work and has been proven, 8 mm silicone like Magnacor or STI. Too many other brands have a tendency to not hold up to the heat in our engine compartment and fail.
Old Feb 17, 2012 | 12:53 PM
creepin's Avatar
You dont think NGK is proven.....I woudnt say there not proven...
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Chrisinhouston
May 2, 2010 09:15 PM
sparky
Defender
Jun 3, 2007 05:10 AM
