po171,po174
Old Nov 9, 2006 | 05:21 AM
LandRoverq's Avatar
Default po171,po174
70,000 miles. Replaced plugs, wires,ect,tps, all O2 sensors. Generic OBD II Fires off PO171 & PO174. I cannot get a in depth analysis from this scan tool.
The truck's performance increased significantly with the tune up. Yet it still has a case of the original symptoms; loss of power upon start up, Misfire when throttle engaged during warm up, loss of acceleration. Any comments would be helpful. Thanks!!
Old Nov 9, 2006 | 08:51 AM
Default RE: po171,po174
Well you are running way to lean, what year is it, have you changed your fuel filter, considered cleaning your injectors and have you checked for a vacumn leak?
Mike
Old Nov 17, 2006 | 01:43 AM
Jwilk's Avatar
7th Gear
I had the same codes, ended up replacing the Mass Air flow Sensor and haven't had a code since.
Old Nov 17, 2006 | 11:37 AM
ORIGINAL: LandRoverq
Are you still having your problem?
MAF is a possibility so is excess carbon when it comes to a misfire as well as dirty or failing fuel injectors or low fuel pressure, have you replace the fuel filter???
Mike
Robover01
Oct 30, 2009 08:02 PM
philiplarson
Jul 16, 2009 10:06 AM
carl.plansky
Aug 10, 2008 08:31 AM
D2Steve
Jul 1, 2008 07:37 PM
cottonpatchweims
Jan 7, 2005 12:50 PM
