PO171, PO174, PO733, PO734 Code Advice Needed
Old Jul 1, 2008 | 01:33 PM
D2Steve's Avatar
3rd Gear
Default PO171, PO174, PO733, PO734 Code Advice Needed
Newbie, here. Just went to Autozone to have my check engine light diagnosed and the following codes came up: PO171, PO174, PO733 and PO734. After perusing the forum I saw that it could be fuel filter and/or mass air flow sensor related. I guess I would like some advice on what steps I should take to aleviate these issues (starting with the cheapest options, obviously).
A couple of other questions: I found the mass air flow sensor on roverparts.com for $217.95. Is this a decent price? If not, any suggestions on where else I should look.
And, for the fuel filter, Autozone is asking for the following engine type:
8 Cylinders 2 4.0L MFI (found in 66% of 2001 Land Rover Discovery II)
8 Cylinders 5 4.0L MFI (found in 34% of 2001 Land Rover Discovery II)
How do I find out which engine I have?
Thanks in advance,
Steve
Old Jul 1, 2008 | 01:38 PM
Default RE: PO171, PO174, PO733, PO734 Code Advice Needed
D2's don't have fuel filters.
Call Tony at Cerrones, 650-365-4145. I believe his prices are in the $180 range.
Old Jul 1, 2008 | 02:49 PM
D2Steve's Avatar
3rd Gear
Thanks, Mike (I told you I was a Newbie).
So I take it you believe it's the Mass Air Flow Sensor? Could this be causing the 733/734 codes, too?
Old Jul 1, 2008 | 03:20 PM
All part of the fault code package when the MAF fails.
Old Jul 1, 2008 | 03:40 PM
D2Steve's Avatar
3rd Gear
Thank you, Mike.
Old Jul 1, 2008 | 04:16 PM
jkid's Avatar
Checkallthe hoses on the engine for vacuum leaks, make sure all the connections are tight. That's the cheapest place to start.
Old Jul 1, 2008 | 04:31 PM
Always good to do but has nothing to due with these codes.
Old Jul 1, 2008 | 07:37 PM
jkid's Avatar
Sorry, I should have elaborated. I had all of these codes on my truck. I had these codes over the course of a few months. First one tranny code every once in a while, then the lean codes and then all four codes everytime it was driven. A new MAF did not fix it. I tightened one of the hoses that threads into the throttle body plenum and I never got a code again. I'm guessing the connection was slowly loosening up over time. It makes sense: bad MAF = unmetered air getting in and a vacuum leak = unmetered air getting in and making itrun too lean.
Robover01
Oct 30, 2009 08:02 PM
philiplarson
Jul 16, 2009 10:06 AM
carl.plansky
Aug 10, 2008 08:31 AM
LandRoverq
Nov 17, 2006 11:37 AM
cottonpatchweims
Jan 7, 2005 12:50 PM
