popping noise in rear end 03 DII
Old Apr 26, 2013 | 01:48 AM
  #31
TRIARII's Avatar
What about body mounts? Forgot if thats what their called but its worth looking into.
Old Jan 8, 2015 | 09:44 PM
  #32
markle0258's Avatar
4wd High
did we ever figure this out? i have a similar problem, just changed shocks and brakes and my rear end is popping whenever i hit speed bump, pot hole ect.. it feels like the drivers side rear. however, no popping when turning. thanks for any input.
Old Jan 9, 2015 | 08:05 AM
  #33
ZGPhoto's Avatar
Have you tested your watts linkage?
Old Jan 9, 2015 | 08:31 AM
  #34
dusty1's Avatar
get a buddy/wife/offspring/life partner/some body to rock the truck side to side while you lay under it and listen at the watts linkage. it is easy to locate it as a source that way. prolly is more towards drivers side of rear axle.
Old Jan 15, 2015 | 12:37 PM
  #35
ruffram's Avatar
I chased this noise for a year. I changed out sway bar links, sway bar mounts, all the watts link bushings etc. For me what fixed it was the 4 large control arm to frame bushings. Mine needed all four replaced ar 135k miles. It is deceiving because the old worn out ones look just like the new ones there were no signS of wear. But when I replaced all four the clunking noises stopped completely. They are a pain to do. Torch out the old rubber and then use a hacksaw to cut the old metAL ring and punch it out. To press the new ones in takes a lot of pressure. I tried using a jack to press against the frame of the truck but it just raised the truck off the ground. Probably need to borrow a press at a machine shop to press them in. That's what I did at least.
Old Jan 15, 2015 | 01:08 PM
  #36
Motorhead1's Avatar
Same happened to me....turned out to be a bad TF rear shock. Was replaced under warranty (Thanks Lucky8!).
Aaron Wasson
May 16, 2013 06:35 PM
jhill15
Dec 15, 2012 11:15 AM
CUpgt
Apr 14, 2010 10:48 AM
LarDog44
Jun 26, 2006 11:39 PM
