Porting and Polishing Experience
Old May 2, 2018 | 02:13 PM
  #101
PalmettoDisco's Avatar
Pricey, but header by ed has aluminum flanges, as well as finished flanges ready for tubes, for the 215..
That site implies the 215 has a difference of about an 1/8" in between the center ports from other buick motors, the 215 requiring 6.03" between these ports.
The nailhead flanges are steel and much, much cheaper. Assuming they are slightly off the necessary 6.03", simply cut the flange in half and weld back at correct measurement.
Old May 2, 2018 | 02:15 PM
  #102
Alex_M's Avatar
Also just ran across these. In theory they should work. A bit pricy though.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F27 1015843008
Old May 2, 2018 | 02:17 PM
  #103
Alex_M's Avatar
1/8” isn't much. Should easily be made up. Hell, if you're going full butcher on it, just team out the bolt holes. I do not condone this idea, but it is the kind of thing I would do at the end of the day when I was tired and the beer had run dry.
Old May 2, 2018 | 03:14 PM
  #104
Custom header tech:
http://garage.grumpysperformance.com/index.php?threads/building-custom-headers.961/
Good info and links.
BTW, I found some rectangular flange stubs for $53 (Set of 8). These are 1.75 x 1.25, if I recall correctly. Not sure of our port size. These are 16 gauge, so minimally adequate.
Old May 8, 2018 | 06:22 PM
  #105
CollieRover's Avatar
So I ported the manifolds with the carbide bit. Worked great. I moved quite a bit of metal in this job. Passenger side required more attention, but both needed it.
they are dipping in rust remover and I will clean them up tomorrow, paint on next dry day.
Old Jun 17, 2018 | 09:02 PM
  #106
Thought I would report back on performance after the Porting and Polishing job. Drove to MPLS and back from Chicago.
Hard to say how much of the improvement is from the porting and polishing, or from simply having good head gaskets.
The most noticeable difference with the motor is the idle. I was hovering below and above 650 prior to the HG job. It’s now hovering around 670, this is in drive. I don’t really monitor it in park, because I just don’t sit around in P a lot.
Acceleration, throttle response are notably better. Throttle cable is adjusted the same way.
On the highway, there is noticeably better throttle response. It’s pulling better, and does seem to be breathing better. Honestly, it’s no corvette, but passing at speeds 70-80 has improved.
Gas mileage has improved a little or not at all. Difficult to say. On the way up I got .5 MPG better than my previous trip, but on the way back it was windy so who knows, plus I had the car loaded down pretty good both ways.
Verdict is I am very happy I did the work, and did not bugger it. It seeems to, at the very least, have done no harm. Difficult to say if the differences I am feeling are from simply having good head gaskets, or of the porting worked.
Old Jun 17, 2018 | 09:03 PM
  #107
Saturnine's Avatar
Nice work!
Old Jun 18, 2018 | 07:24 AM
  #108
Originally Posted by Saturnine
Nice work!
Thanks!
I should have mentioned I got new fuel injectors as well.
Really happy with how she is running.
Old Jun 18, 2018 | 07:31 AM
  #109
Alex_M's Avatar
Glad to hear it all came out well!
Old Jun 18, 2018 | 07:36 AM
  #110
Honestly, I wouldn't have attempted it without your help, so thanks again.
