Porting and Polishing Experience
Old Apr 8, 2018 | 04:54 PM
  #31
OffroadFrance's Avatar
Originally Posted by Sixpack577
prussian blue
paint it around the ports in the head, and set the lower intake in place, or vice versa
X1 ......... cleaning up any lumps and bumps on the intake and any manifold mismatches will assist the intake mixture flow and improve efficiency but in isolation from other more radical tuning any gains will be minuscule. IMO don't mirror polish the ports but leave them with a radial medium to fine grit finish as this improves mixture swirl and tumble before entering the cylinder head.
Old Apr 8, 2018 | 06:04 PM
  #32
CollieRover's Avatar
thanks for all of the advice guys.
the Eastwood instructional videos say to only use 80 grit on the intake to allow the air to tumble, or some term like that.
I’ve seen other videos that say to really shine the exhaust ports though.
Old Apr 8, 2018 | 07:43 PM
  #33
Sixpack577's Avatar
Rough or smooth ports have been debated for a long time. Rough seems to be the consensus, and is obviously much easier to do.
What you're really trying to do is make sure the head ports are as big, or just barely bigger than the intake.
So the flow doesn't bottleneck, or cause turbulence from hitting the edge of the head port's wall, sticking past the intake's port's walls.
I have had my engine apart for months, with plenty of time to have port matched it. But, I didn't want the hassle.
Any gains would be small, but I wouldn't be suprised if it smoothed out the engine at certain rpm's.
Those are the things that would be nice to do before and after dyno runs, to see how the power curve changes.
Old Apr 8, 2018 | 07:47 PM
  #34
Saturnine's Avatar
Dyno and Land Rover don't belong in the same sentence.
Haha
Old Apr 8, 2018 | 08:24 PM
  #35
Alex_M's Avatar
I disagree. I'd actually really like to Dyno a stock engine and my engine to see exactly what I've gained. I'd really be interested to also do a chassis Dyno to see what the drivetrain losses are on these beasts.
Costly though. Not really worth the cost unless I was getting it tuned, which won't happen unless I go to an aftermarket ECU.
Old Apr 9, 2018 | 05:06 AM
  #36
Haha
X1 .............. so true.
I wish I had a dollar for every engine I'd sent to the dyno shop, I'd be mega rich now and ................. none of them were Landrover engines of any type/age
Old Apr 9, 2018 | 06:05 AM
  #37
I picked up a dremel 3000, and will be ordering the Eastwood porting kit. Will try to take pics for the thread.
I’m excited about having the tool. I am going to use it to make thread chasers as well.
Unfortjnately, it’s still really cold, snowing here in Chicago. I just want to get started!
Old Apr 9, 2018 | 10:27 AM
  #38
Returning the Dremel 3000, and ordered a 4000. The 3000 is small, and for $15 more the 4000 seems a good upgrade.
Using these products from Summit Racing. The Eastwood kit is nice, and has mandrels, but this kit has more grits to use. As stated, starting without using a carbide bit.
SUM-G1060
Port and Polishing Kit, 92-Piece, Cartridge Rolls, 60/80/120-Grit, Assorted Sizes, 1/4 in. Shank Mandrels, Kit
(Mfr. #: SUM-G1060)
SAI-716296
Mandrel For Cartridge Rolls, Steel, 6 in. Overall Length, Each
(Mfr. #: 716296)
I am going to use a fine Blue Sharpie to mark the edges of the Gasket, then filling the center with a light blue sharpie.
I will report back with before and after pics when I have the time.
Old Apr 9, 2018 | 10:50 AM
  #39
Saturnine's Avatar
Just make sure to stay in the lines!
Old Apr 9, 2018 | 11:00 AM
  #40
That is the reasoning behind the two colors the fine sharpie is where I will stop.
