POS...ahhh...PAS Pump
I need a rebuilt power steering pump for 2001 D2. Best price I can find is at RoverLand Parts. $297 delivered. Anybody know of one cheaper, or better?
1999-2004 Discovery II Power Steering Pump
on
Trust me when I say, the cheaper you go with a rebuilt P/S pump the greater your odds of replacing it many times cause most rebuilt pumps always fail. You would be better off buying a good used, non leaking pump for less with less chance of it leaking.
In your case, exactly where is the leak and how are your hoses.
AutoZone looks like a good deal, and the pump has a lifetime warranty. @ Mike..Pump doesn't leak, has a loud growl and stiff when it's cold. over a year ago it started growling, and I changed fluid and added Lucas and bought some time. I tried that route again, but it's to far gone. When I tear it down I will check the condition of the hoses.
I've tried rebuilding/resealing mine about three times now, every time it just seems to leak and still not give any sort of power assistance. Tried those cut-a-gaskets and various RTVs. I've just given up for now, I honestly don't really mind it anyways. Even with the larger tires I only have problems when navigating tight parking spots. Plus I can use it as an excuse to not get to the gym as much.
asat
11-03-2008 09:59 PM
