pos land rover
Old Jun 12, 2007 | 09:22 PM
suntattoo80's Avatar
Default pos land rover
ok im fed up i'v had this 2000 d2 for 1 yr now. i'v put 8,706 miles on it with nothing about it being reliable. first i had a hub berring go bad left rear. next ac now make for work....bad shrader valve. next crank position sensor go bad... now im getting a stearing prob with it going down the highway it will drive great at the off ramp i loose all power assisted steering. i tell you for the money and time it's no longer worth it to me. im a mechanic for a living and i cant keep up with this thing... so i guess my question is whats with the steering... fluid full and clean i flushed it 3 days ago. no leaks....???anyone???
Old Jun 13, 2007 | 08:31 AM
Landzu's Avatar
Default RE: pos land rover
Point Of Sale ?
I know that the Disco I must use Dex ATF if not seals will go out.
From the power steering flushs I have done the fluid is not ATF
that goes back in.
Good Luck.
Old Jun 13, 2007 | 08:37 AM
You may want to replace part of your steering fluid with a bottle of Lucas power steering additive and give it a day or so to work, usually will clear up issues like that.
Let us know how it goes.
Mike
lucky139
Jan 10, 2012 06:10 AM
imaric
Sep 28, 2010 09:04 PM
Spencerfitch
Sep 20, 2010 03:25 PM
Arsenal 1
Feb 20, 2010 12:32 PM
asat
Nov 3, 2008 09:59 PM
