Positive battery terminal replacement
Old May 14, 2017 | 04:27 PM
huggi's Avatar
Default Positive battery terminal replacement
My positive battery terminal doesn't grip tightly. I know I can put a shim under it.
I plan on replacing the terminal. Will the following work?
Amazon Amazon
I think the two wires are 0 gauge.
Thanks
Old May 14, 2017 | 04:42 PM
Jeff Blake's Avatar
Not a fan of screw-type terminals. Crimping is 1000x better. The screws will work loose and allow moisture & corrosion build up which will wick down the cable and be bad news bears.
Go with something like this:
Amazon Amazon
And use copper lugs. A hydraulic crimper is about $45 on amazon.
Old May 14, 2017 | 06:30 PM
huggi's Avatar
Thanks for the advice Jeff. Will our positive cables fit in the 2 gauge lugs in that kit you posted?
Old May 14, 2017 | 08:41 PM
Jeff Blake's Avatar
No, you need either 1 gauge or 1/0 gauge lugs, I can't remember which
Old May 14, 2017 | 09:55 PM
mln01's Avatar
I don't understand you want to go to all the extra work to change terminals. I have shimmed mine off and on over the years with different materials, ranging from a toothpick to a small screw driven down in between the terminal in the post (into a pre-drilled hole).
I was surprised two days ago, however, that when I replaced the battery the posts were apparently just enough larger that no shim was required. The factory terminals tightened down to be quite snug.
Old May 14, 2017 | 10:18 PM
Jeff Blake's Avatar
I could think of half a dozen reasons... but to each their own
And it's hardly 'that much work' at all. Snip, crimp, shrink, done.
Old May 15, 2017 | 03:22 AM
robh's Avatar
Go with something like this: https://www.amazon.com/Military-Spec...ttery+terminal
Jeff, that's a nice looking battery setup. Are there details or maybe a writeup on that floating around somewhere?
Old May 15, 2017 | 10:57 AM
Jeff Blake's Avatar
I made a thread over at expedition portal, but it's not that thorough.
Electrical Build (Dual Batt, Solar, Inverter, Charger, Panels, Fridge) LR Discovery 2 - Expedition Portal
Old May 15, 2017 | 11:05 AM
JUKE179r's Avatar
Cheers mate!
Old May 15, 2017 | 11:26 AM
robh's Avatar
Great, thanks! Looking forward to digesting all of that.
batard
Jul 15, 2016 05:11 AM
batard
Apr 13, 2016 09:26 PM
mherson
Oct 28, 2010 08:15 PM
thomas22
Jul 25, 2009 04:35 PM
98roverguy
Aug 22, 2007 05:52 PM
