Possible dust in upper cylinders and start up questions
Old Aug 28, 2023 | 12:48 PM
neuropathy's Avatar
Thanks, good points. Someone had told me to check the tank since it’s sat for a while. Is there anything special I should do since it’s sat for a while and I’ve turned the engine maybe 10 times by hand for the timing chain and everything? Just put the plugs in and get pressure to the new oil pump with the fuel relay pulled? Or with a spoon of MMO in each cylinder and without plugs and fuel relay at first? I’m really not understanding if there’s anything special I should do beyond just starting it like others have said when you’ve installed a new oil pump (and water pump and PS pump, but I know those procedures).
Old Aug 28, 2023 | 03:57 PM
Dweeb Discovery's Avatar
Just put everything together and start the truck.
Don't overthink it.
I understand you are being careful. That's great. But this much anxiety is not healthy.
Jwilson713
Feb 23, 2020 09:51 PM
sir.duff
Jun 12, 2016 09:24 AM
DiscoHotRod?
Apr 23, 2015 03:55 PM
highlander999
Nov 2, 2008 09:00 AM
Kraftyz51
Nov 21, 2007 09:15 AM
