Coolant Leak Drivers side close to firewall.
Old Oct 11, 2012 | 05:58 PM
Enigma753's Avatar
4th Gear
Default Coolant Leak Drivers side close to firewall.
Let me thank everyone for this forum, it has been a great help with my 99 Discovery II.
I have completed the hose replacements, waterpump replacement, relays and anything else I can find unless it finds me first.
I have had a small loss for a while but never could find it. Took kids to the lake and I couldn't get out of the truck well enough before I see the coolant rolling from under the vehicle.
Res was full so feed the ducks and drove it home (very close). I jacked the truck up, started it. From under the truck I could see the steady stream of coolant (pin head stream).
Res was down significantly turned the car off. I'm bummed because I just finished the starter and that was difficult to me, at least to get apart to get to it. Got it back in fine.
My question is what is in this area, valley pan, head gasket?
Thanks for any info
Old Oct 11, 2012 | 06:07 PM
There are two lines that feed/return from the throttle body heater. Replacement kit is like $25. Also HG, valley pan, maybe freeze plugs. You can remove line from throttle body heater and shove them together to see if it stops.
http://www.roverparts.com/Parts/MGM000010K.cfm
Old Oct 11, 2012 | 07:01 PM
And the head gaskets.
Time to do a coolant pressure test to find the leak.
Old Oct 11, 2012 | 07:06 PM
jfall's Avatar
Use your cell phone
Take a picture of the leak.
Email the picture to yourself.
Then post it on here.
Old Oct 11, 2012 | 09:56 PM
And here is a plumbing map, in case it is a loose hose clamp (vs the always unpleasant HG). The pressure test will reveal the source, may take a few minutes once pressure is run up to say 15 PSI. Cap vents at 18, no need to go that far.
File Type: pdf
Old Oct 13, 2012 | 12:05 AM
Enigma753's Avatar
4th Gear
I will work on what your asking and get back in here with the information.
Vai2kdna77
Apr 17, 2015 01:22 PM
gusbone
Oct 7, 2012 09:10 AM
matt3502
Nov 12, 2010 01:29 PM
tads
Aug 20, 2007 03:41 PM
