Possibly Going to Buy a Disco!
Old Jul 14, 2009 | 11:30 PM
LRScott's Avatar
Default Possibly Going to Buy a Disco!
Well, I found a 95 discovery that might be a good one to buy. The only real concern I have with it, is it makes a grinding noise that is coming from either the transmission or the transfer case. My thoughts are either the wrong type of ATF, the torque converter and possibly the transfer case chain. Which brings me to my question. Do discovery Is have a transfer case chain? Because, I cannot find the part for a discovery I. Thanks in advance!
Old Jul 15, 2009 | 12:49 AM
NiteTrain's Avatar
I would only buy that disco if you can get it cheap. I mean $1,000-1,200 cheap.
Old Jul 15, 2009 | 01:57 AM
LRScott's Avatar
Its $900, the problem is I have to drive 400 miles to get it home, and I am concerned.
Old Jul 15, 2009 | 02:12 AM
khuds308's Avatar
tell the dude you will give him $500 because it's a **** truck, and then you can get it towed. you shouldn't drive a car that makes a grinding sound from the trans. or t-case. Hell i would go so far as to say maybe you shouldn't drive are vehicle with a grinding noise comen out of anywere.....
Old Jul 15, 2009 | 09:14 AM
antichrist's Avatar
No, they are all gear driven. What part can you not find?
Old Jul 15, 2009 | 12:28 PM
NiteTrain's Avatar
rent a trailer and pull it home with your RR
Old Jul 17, 2009 | 12:05 AM
LRScott's Avatar
The RR would probably blow up on the way over lol. If it were only 6 hours away and the roads were pretty straight and level, I would definitely use the RR and haul it back. But, the drive is very windy, mountainous, and hazardous in some seasons. I am having second thoughts about the disco but, who knows. I might change my mind overnight. From what the owner is telling me (I haven't actually looked at it yet), the grinding noise sounds like it is an axle problem. It is a continuous noise.
TATZOO
Jun 10, 2013 05:22 PM
jpluncford21
Nov 14, 2011 08:48 AM
The Madhatter
Jun 21, 2009 11:25 PM
sterlingheights
Apr 14, 2009 08:10 PM
