Potential downsides of "the best PCV mod" on a Discovery 2?
Old Oct 17, 2024 | 03:51 PM
H20nSnow's Avatar
Originally Posted by ACEBROKE2
I can't remove the black baffle and gave up trying. Half broke off. Sprayed it with Brake cleaner. Put in a screw. Big pliers. Pulled Full force. Won't budge. Gave up trying. Don't want it falling inside.
I figure as long as I spray it to keep it breathing it will do what it's supposed to do.
Wanted to complete this Mod but couldn't.
Pull the fitting out of the valve cover and push the baffle out from the back. Easy. On mine, I applied pulling force to the hose with one hand while twisting the sleeve back and forth with pliers and it slipped right out of the valve cover.
Old Oct 17, 2024 | 03:55 PM
ACEBROKE2's Avatar
Can't pull it out and If I push it in I have to take off the valve cover...
Old Oct 17, 2024 | 04:00 PM
Extinct's Avatar
This
Old Oct 17, 2024 | 04:23 PM
H20nSnow's Avatar
The stainless steel sleeve that the baffle is in is what you take out of the VC. Then you are free to do whatever to get the baffle out without anything falling into the head. You need to pull it anyway since you want to open up the hole in the downhill side of the sleeve.
Old Oct 17, 2024 | 04:35 PM
mollusc's Avatar
The tube won't push into the valve cover. There are baffle plates inside that will stop it going down.
Use a pipe wrench or slip-jaw pliers to twist the stainless tube free and it should pull right out.
Old Oct 19, 2024 | 12:34 AM
nashvegas's Avatar
Zero downsides. I'm on my 6th or 7th Disco that I've done this on...
Old Oct 19, 2024 | 05:54 AM
mln01's Avatar
According to Best4x4, the fitting is removable only on '03 and '04 Discoveries with the 4.6L engine. It's not removable on pre-facelift, '99-'02 trucks.
Old Oct 19, 2024 | 09:34 AM
mollusc's Avatar
I pulled the fitting out on my '99. It's just a tube that's pressed in place.
Old Oct 19, 2024 | 12:02 PM
mln01's Avatar
Originally Posted by Extinct
PCV valve serves two purpose. It did prevent crankcase explosions due to backfires, not as much a problem with modern fuel injection but still non-zero. The baffle will do the same thing. It also acts as a restrictor, just like the baffle does. There are two crankcase vents, one upstream of the throttle and one downstream. The upstream one only sees lower vacuum conditions, so it does not need to be baffled. The one downstream of the throttle sees very high vacuum would pull too much oil in to the intake if not restricted (common problem on the 5.3 LS truck engines - the removed the PCV valve also) so LR uses a baffle but the problem with the baffle is it plugs over time whereas the pcv does not. It would not be a good idea to just plug a baffle-less hose on the fitting in the intake.
Extinct, thank you for the explanation. I hope you appreciate why I thought of the question.
Interesting. I could swear Best4x4 said otherwise. Oh well. A friend is trying to do the PCV mod on his pre-facelift truck and has had trouble removing the oil separator. We'll give this a try and see what happens.
Old Oct 21, 2024 | 01:26 AM
nashvegas's Avatar
It is removable on all of them, 99 thru 04. I can assure you of this fact !!!
GavinC
Yesterday 04:56 PM
okdiscoguy
Jan 16, 2024 04:31 PM
Alphamale
May 3, 2015 09:35 PM
yorocky
May 17, 2014 04:55 AM
