Power to the roof rack?
Old Nov 16, 2017 | 09:44 AM
Greg Vasileff's Avatar
Default Power to the roof rack?
If I decide to put lights on my roof rack, how are you all getting it there?
Old Nov 16, 2017 | 10:13 AM
BackInA88's Avatar
I ran the wiring to the back and just have it go into the truck thru the rear door in the upper right corner. Than I have a plug in the plastic cover in the rear.
Old Nov 16, 2017 | 10:47 AM
Alex_M's Avatar
Up the inside of the A pillar, above the headliner, through the roof into the roof bar, then out the bar on the underside so water can't enter.
Old Nov 16, 2017 | 12:25 PM
Frank4's Avatar
From a power source under the hood, run the wires under the black plastic cover on the A pillar to the rack. No need to drill a hole in your roof.
Old Nov 16, 2017 | 02:45 PM
KingKoopa's Avatar
Originally Posted by frank4
from a power source under the hood, run the wires under the black plastic cover on the a pillar to the rack. No need to drill a hole in your roof.
x2 ^^^
Old Nov 16, 2017 | 09:06 PM
Jeff Blake's Avatar
To add onto the a-pillar suggestion, I used Ancor Marine 10awg duplex wire (two 10 awg wires bonded together https://www.westmarine.com/buy/ancor...09_274_003_002). This stuff is rigid enough on its own to snake behind the pillar without removing the pillar or having to rig up a steel wire to piggyback the wire through. Easy peasy. That cable powers my LED bar
I also have two of these: https://www.mcmaster.com/#standard-cord-grips/=1aado06 on my roof.
One is a 7-wire trailer cable. One wire is routed to a negative ground bus on the roof rack, leaving me 6 separate power wires to do whatever I want up there. This way, you drill the roof once to accommodate any future accessories. At the moment, I just have rack mounted backup lights.
Second is a 2x 10 awg gland for the solar panels.
Oasisplayer311
May 7, 2015 09:42 PM
Oasisplayer311
May 3, 2015 03:00 AM
mx468
Sep 19, 2012 07:21 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
