No power to fuel pump on '04 DII
Old Nov 2, 2017 | 06:44 PM
gulfst's Avatar
8th Gear
Default No power to fuel pump on '04 DII
Any ideas why I have NO power to the fuel pump when the ignition switch is in Position II. Only power when cranking. NO P codes or Check Engine light showing. Engine cranks but will not start.
Old Nov 2, 2017 | 08:33 PM
Best4x4's Avatar
Do you have spark? It will only give you spark/fuel if it see's a signal from the CPS.
Old Nov 2, 2017 | 09:06 PM
gulfst's Avatar
8th Gear
Sorry I should have mentioned that earlier, I do have a spark. Also replaced fuel pump (filter was clogged) and CPS
Old Nov 3, 2017 | 06:03 AM
The Deputy's Avatar
You say there is power to the pump when cranking (which is normal). But, you didn't say if you can hear the pump running. You have spark, does it fire up on ether/starting fluid?
Also, a bit of back-story might give us more clues. Like was it running and just quit going down the road, or did you park it and it wouldn't start the next time tried, or was it running before you worked on it and now it's not, etc, etc?
Brian.
Old Nov 17, 2017 | 08:29 AM
gulfst's Avatar
8th Gear
Threw in the towel and got towed to Motor Cars Ltd ( Independent British Car repair in Houston. Good people and great pricing on parts New, Used, OEM Jaguar Parts and Land Rover Parts )
Here was the fix. Got a call from the service manager that my fuel pump was bad and not producing enough pressure at the rail. Really! My "new fuel" had already gone bad after 37 miles! I could hear the pump running but could not find the shreader valve on the fuel rail to check the pressure. The forum tells me it is hard to get to on the D2. No kidding. Couldn't even find the bloody thing!
Motor Cars Ltd had sold me the original pump so they replaced it and 500 miles later truck runs great. Heading to Big Bend NP next weekend to see the Milky Way all all the stars. Darkest skies in the lower 48. Great place for Lucas electrical systems!
Old Nov 17, 2017 | 08:48 AM
gulfst's Avatar
8th Gear
Thanks for all the help. Valve gasket replacement next after the New Year. Small leak from RH head on to exhaust manifold. No drips on garage floor
____________________
'04 Discovery 128K
'13 BMW 528 XI
'06 Porsche Carrera 4S
Whole bunch of motorcycles ( '75 850 Norton, '67 250 Benelli, 5 Ducatis)
Old Nov 17, 2017 | 09:51 AM
Best4x4's Avatar
Motorcars LTD isn’t the best place to get LR’s fixed & their parts are $$$$$ IMHO. There is a much better LR Shop up by Spring, TX.
The fuel pump on a D1/D2 is a breeze to find/replace. Good luck on the Big Bend Trip.
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
Sandman0306
Dec 15, 2012 03:24 PM
JumPeR04
Apr 7, 2011 09:52 PM
marcwestbmw
Dec 4, 2009 03:29 PM
