power steering
Old Feb 9, 2010 | 08:00 AM
chad420's Avatar
Default power steering
Have a leaky power steering hose. I ordered the hoses from AB. Anything I should be aware of before I start the project??? Thnaks
Old Feb 9, 2010 | 09:02 AM
You will need a fan hub wrench, 36mm in size, so you can remove the fan then the p/s pump pulley.
Order a new belt since you will be removing the old one, and make sure you flush all the old fluid when putting it back together.
Old Feb 9, 2010 | 10:23 AM
mlahaie79's Avatar
is it common for a power steering hose to leak? Mine started leaking fluid this morning and is whining when i turn the wheel. Not sure if its leaking from the hose into the pump or the pump itself.
Old Feb 9, 2010 | 10:30 AM
lipadj46's Avatar
I think it is more common for the pumps to leak from the center paper gasket but hoses can leak too. The o'ring on the high pressure fitting and the clamp on the low pressure hose are common failure points.
Old Feb 9, 2010 | 11:30 AM
okdiscoguy's Avatar
Check your fluid! If it is whining, you are low on fluid, something is restricted in the line, or your pump is about to go!
Old Feb 10, 2010 | 06:22 AM
mlahaie79's Avatar
I had a slow drip before this and put regular power steering fluid in it (which I know now is a no no) and then it started whining and now the big leak...could it be that the pump really doesn't like that fluid?
Old Feb 10, 2010 | 10:08 AM
okdiscoguy's Avatar
Yes. Poeple say the 2 are compatible, but I disagree. You need to flush out all of the fluid and replace with ATF. PS fluid has a higher viscosity. This will make your pump strain and give you a higher pressure, which is why you are leaking.
Old Feb 11, 2010 | 08:57 PM
demonlarry's Avatar
Default Pentosin
do they take ATF? or Pentosin?
Old Feb 11, 2010 | 08:59 PM
demonlarry's Avatar
never mind, answered my own question
atf
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
