Power steering
Old Jul 12, 2013 | 11:12 AM
Jared Shively's Avatar
7th Gear
Default Power steering
Just a quick question.. How hard is it for you to turn your steering wheel? Mine is not difficult at all really, but it is a lot more 'stickier' than it was in my last vehicle (2005 GMC Sierra)...
Is there a way to make it easier to turn? Fluid seems to be full, belts have been changed.. or is it just normal for the wheel to be a little more stiff?
Old Jul 12, 2013 | 12:18 PM
Big difference between a GMC and a Rover and you have found one of them.
No, there is no fix for it other then keeping fresh fluid in it every 20,000 miles.
Old Jul 12, 2013 | 11:06 PM
MeanSaleen's Avatar
anyone know the size of the fitting on the side of the power steering pump that goes to steering box? i believe its a flare fitting. On a pump change i should be able to remove old fitting to put on new pump? no?
Old Jul 13, 2013 | 12:29 AM
DIIZ's Avatar
I just had my power steering pump and low pressure hose replaced. And now I can turn my wheel with one finger. The thing I noticed is that over time the entire system starts to get a bit clogged up, so just topping it off won't really fix that problem. A fluid flush might help your steering become more responsive. But I will warn you... this isn't a cheap thing to do... But still worth it in my opinion.
Old Jul 13, 2013 | 06:17 AM
jfall's Avatar
Does Kenny Shivley know you have a rover?
Old Jul 13, 2013 | 07:38 AM
MeanSaleen's Avatar
Anyone?
Old Jul 13, 2013 | 09:33 AM
Anyone?
Might start your own thread instead of asking an unrelated question on here.
Old Jul 13, 2013 | 10:19 AM
MeanSaleen's Avatar
Now I understand what they mean
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
