Power Steering fluid
If you want that warm fuzzy feeling get some fuzzy dice.lol
Well here is the problem that I see. DI's take ATF in the power steering system, if you use a power steering fluid additive then you are mixing two incompatable fluids.
If you have a DII then you can use a power steering fluid conditioner. DII's use power steering fluid in the power steering system.
So if you have a DI you could use a ATF fluid conditioner.
jycsalas
04-17-2009 02:21 AM
