power steering fluid
Old Oct 2, 2007 | 09:35 AM
jdelp's Avatar
Default power steering fluid
To change this out, do you disconnect one of the hoses at the bottom of the reservoir or is there a drain plug beneath the pump somewhere?
Old Oct 2, 2007 | 10:08 AM
Default RE: power steering fluid
The way you have described is a real messy way to do this, call me and I'll walk you thru a much cleaner, easier way.
303-862-7680
Colorado between 7 am and 8 pm
Old Oct 3, 2007 | 09:45 AM
Aquaholic's Avatar
I've always used a turkey baster to suck out all the fluid I can, clean the reservoir, then add new fluid. It doesn't change it all, but it's worked for me.
Old Oct 3, 2007 | 10:08 AM
jdelp's Avatar
That's how I did it before, but figured there was a better way to change out all the fluid w/ the 60k service.
Old Oct 3, 2007 | 10:55 AM
You are both on the right track. buy 2 quarts of Vavoline synthetic power steering fluid and a bottle of Lucas. Use your turkey baster, suck out all the fluid, refill then start the steering , turn the steering wheel both ways to full lock, turn off the engine suck out the fluid and repeat. May need to do this 3 times, then fill the bottle with the Lucas topping of with whats left of your Vavoline and your set.
It is a little waist full as to the amount of fluid, but there is no mess on the ground and by doing the refill 3 times you get better then 90% of the old fluid out and have a quieter pump.
Old Oct 3, 2007 | 11:05 AM
jdelp's Avatar
Good deal. And here I thought I was being lazy by not undoing the hoses
jycsalas
Apr 17, 2009 02:21 AM
humroot
Nov 11, 2007 08:58 PM
willlane
Nov 10, 2007 07:33 PM
discoken
Jul 4, 2007 05:29 PM
nanin
May 12, 2007 10:09 AM
