power steering fuild
on
RE: power steering fuild
See if you can see the drain tube under the power steering gear, if not get back to me and I'll call you and walk you thru how to do it with out making a mess.
I would suggest using 2 quarts Vavoline's synthetic power steering fluid and a small bottle of Lucas power steering additive to keep the pump happy for years.
on
Rover's have too many power steering pump issues, why help it along. Actually The owner's manual states to use Texaco cold climate PAS fluid, 14315.
I have found that both my ACE and the power steering pump are quieter and the fluid doesn't burn nearly as fast as with Dextron. I have learn that you go with what works best.
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
rangerover88
10-02-2006 06:14 PM
