power steering fuild
Old Sep 2, 2007 | 09:58 AM
gtagg's Avatar
Default power steering fuild
I want to change the power steering fluid in my disco II is there anything I should know or do? what type of fluid should I use?
thanks gents
gTAGG
Old Sep 2, 2007 | 11:38 AM
Default RE: power steering fuild
See if you can see the drain tube under the power steering gear, if not get back to me and I'll call you and walk you thru how to do it with out making a mess.
I would suggest using 2 quarts Vavoline's synthetic power steering fluid and a small bottle of Lucas power steering additive to keep the pump happy for years.
Old Sep 2, 2007 | 10:45 PM
paranoidfreud's Avatar
6th Gear
Where is the power steering gear? I may attempt this and also changing the brake fluid. I'm not a gear head, but can follow directions well...think I should have a go at it?
thanks.
Old Sep 2, 2007 | 10:50 PM
ajh's Avatar
ajh
Another option is using something like Amsoil Synthetic ATF.
Old Sep 3, 2007 | 08:37 AM
ORIGINAL: ajh
Not an option in Rovers steering if you want the power steering pump to hold up. Power steering fluid be it standard or synthetic only.
Old Sep 3, 2007 | 09:38 PM
mordor110's Avatar
What's the difference between ATF & P/S fluid? My Disco owners manual says to use Dexron II ATF? Which I have been but will change it if there's a good reason? What would be good non-synthetic options?
Old Sep 4, 2007 | 08:06 AM
Rover's have too many power steering pump issues, why help it along. Actually The owner's manual states to use Texaco cold climate PAS fluid, 14315.
I have found that both my ACE and the power steering pump are quieter and the fluid doesn't burn nearly as fast as with Dextron. I have learn that you go with what works best.
Old Sep 4, 2007 | 11:42 AM
okdiscoguy's Avatar
Mike,
My owner's manual says to use Dexron 3 or M2C 33. I even have a ZF on the cap. I am running synthetic PS fluid, but it does say that in the OM..
Old Sep 7, 2007 | 10:47 PM
gtagg's Avatar
O.K. Mike, I don't see a drain hose. I'm not sure I am looking in the right place. can you tell me where to look. Think it would be better to call you? thanks for the come back. its good to know I wasn't to only one with P.S. Issues.
gTAGG
varlean
Sep 11, 2013 06:39 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
rangerover88
Oct 2, 2006 06:14 PM
