power steering leak! need to get the kids home.
Old Feb 21, 2010 | 11:56 AM
lipadj46's Avatar
That bolt is a stud used for locating the pump on the head, it only has a 7lb or so torque spec and (as you found out) it is easy to snap off. Mine was broken off before I got to it. The nut does not to be there as it is only used to hold on the pump until the other bolts are torqued down. AS long a there is enough to locate the pump on the head you should be fine. I'm sure you could find a replacement also.
Old Feb 21, 2010 | 07:51 PM
NyTelTech's Avatar
Thanks for the input, guys. I just got done putting everything back and taking a test drive. So far, the street under my new parking spot is dry and has been for about 2 hours. I hope this holds up.
dusty1
20
Aug 26, 2014 05:07 PM
gribur
Sights N Sounds
Feb 9, 2014 10:31 PM
retroicon
LR4
20
Jun 3, 2013 10:20 AM
Spike555
ROAMING WITH FRIENDS
Jul 1, 2009 09:16 PM
okdiscoguy
Dec 9, 2007 10:27 PM
