Power Steering Level
Old Nov 22, 2025 | 07:02 AM
ryanmalcolmrealestate@gmail.com's Avatar
Default Power Steering Level
Hey everyone, I have noticed as the weather gets colder my cold starts have a whine that eventually goes away. I am thinking its the PSP or maybe just low fluid, my fluid level when cold as you can see is just at the min line..wondering if i should add some from the sahdow its looks like there is more in there than there actually is.... Belts pulleys just serviced so im pretty sure its PS, i can hear the tone change when i turn the wheel in park.
Old Nov 22, 2025 | 03:31 PM
Extinct's Avatar
You likely have a leaking gasket that's allowing some air to get sucked in causing the noise. You can bleed the pump but it might get better for a little while but you're probably going to have to fix the leak
SuspensionFault
Mar 4, 2021 07:09 PM
Glen11
Jun 11, 2014 08:56 AM
novavon
Jun 28, 2010 12:31 PM
blcp86
Jan 14, 2010 06:41 PM
redbaron586
Dec 2, 2008 05:22 PM
