Power Steering Pump=Vibration Issues
Old Jan 24, 2011 | 08:45 PM
Discodude's Avatar
7th Gear
Default Power Steering Pump=Vibration Issues
Hi guys. I'm in the need of a lil assistance. I recently replaced my PS pump. Afterwards, I have a slight vibration during initial startup, idling and take off. It also vibrates a little while idling at a traffic light, etc. Does anyone have any earthly idea what's possibly going on here?. Its driving me crazy guys.
Old Jan 25, 2011 | 09:05 AM
Bad bearing, bent shaft or pulley.
Old Jan 26, 2011 | 06:48 PM
Discodude's Avatar
7th Gear
Default Thanks Mike
I'm pretty handy around my 1999 Disco (156,000 miles). I do most of the maintanance/upkeep myself. I've searched the posts to no avail. Plus, I've downloaded the RAVE CD. I'm NOT an idiot Mike. I would just like a little more clarification so I will know exactly what to do.
Question Mike:
(1) Where are the bearings located and how do I replace them?
(2) Where and which possible bent shaft are referring to?
(3) Are you talking about the Crankshaft Pulley might be bad?
Thanks for all that you do for the Rover enthusiast.
Old Jan 26, 2011 | 09:46 PM
lordmorpheus's Avatar
If the problems began after changing your PAS pump, I would assume all parts referred to my Mike would be pump related: pump bearing, pump shaft, pump pulley. Did you get a new, rebuilt, or used pump assembly?
The quickest and easiest test would be to remove the belt, and see if the vibration continues. Do this on a cold engine so as to not overheat it!!
Andy2Rover
Oct 15, 2024 05:35 PM
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
cobbcj7
Dec 5, 2011 06:26 PM
losinov
Mar 21, 2011 08:57 PM
