Power Steering Pump
Old Apr 16, 2009 | 08:17 AM
LRDiscGirl's Avatar
5th Gear
Default Power Steering Pump
Hi...I have an 03 Discovery (75k) and it has been leaking power steering fluid. It was making a horrible noise when I turned the wheel and progressively getting worse and harder to steer. I added P/S Fluid because it was low, but in just a couple of days it was low again. I got it to the shop yesterday and was told I have a leak in my P/S Pump.
Can someone tell me what I should expect to pay? I don't know much about cars, nor do I know the mechanic I took it to. I don't want to be taken advantage of.
Thanks in advance.
LRDiscGirl
Old Apr 16, 2009 | 08:28 AM
Before authorizing I would either want them to show you exactly where it is leaking and or get a second option. The power steering hoses are also known, and more prone to leaking.
As for cost, a good used pump will run you in the mid $250 range at, http://www.roverlandparts.com/powersteeringpumps.aspx
a new one from Rover Connection will run you $50 plus along with labor. With that in mind, do your homework.
If and when youy get an estimate, get back to use with the labor and parts.
Old Apr 16, 2009 | 08:31 AM
Jawbox's Avatar
This one isn't a cheap repair. A new pump is about $400 and a used pump is still about $300:
I'm guessing they'll want to replace your P/S lines as well which would be $170 new.
The repair itself shouldn't be bad, but it will take at least a few hours of shop time to fix. Mike or Spike can maybe troubleshoot it further.
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
