Power steering pump
Old Aug 22, 2013 | 05:15 PM
Pacerlive's Avatar
Default Power steering pump
So I have had a progressive leak of my power steering fluid and I finally took it into the shop since it was getting pretty bad. THe tech said I needed to replace my pump because the seals were leaking.
Is this common? And my gawd those pumps for a D2 are pricey. I was expecting only to replace one of the lines because thats were I thought I saw the leak. I am kind of curius if I am getting worked by the tech or if those pumps actually develop common leaks.
Old Aug 22, 2013 | 05:20 PM
Celto 4's Avatar
Hi there I got an oem pump from Carquest for a lot less!
Old Aug 22, 2013 | 05:38 PM
Pacerlive's Avatar
Thanks,
I checked it out and its a remanufactored one correct from Cardone? No problems with it yet?
CARQUEST - Product Information:Cardone Reman Power Steering Pumps#
Old Aug 22, 2013 | 06:06 PM
Celto 4's Avatar
Maybe it was particular to this place but it came thru in a Landrover box and I was told it was new
Old Aug 22, 2013 | 06:08 PM
Celto 4's Avatar
I do know that I put their lines in and had problems had to get oem
Old Aug 22, 2013 | 06:21 PM
Be careful with re-built pumps, they have a pretty high failure rate.
Have you actually power scrubbed off the hoses and pump to verify if the pump is leaking, usually it is a hose.
Old Aug 22, 2013 | 07:41 PM
Fivespddisco's Avatar
Agree
IT maybe the cheap hose on the back side.
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
