Power Steering Pump Repair
PD2004USSalty (02-05-2024)
For very sure, the triangular flange slides out of the pump shaft without removing the pump. Try prying out with some bar. A weld blob can deposit enough meat to re-thread.
----> https://landroverforums.com/forum/di...d-belt-113382/
The following 2 users liked this post by Externet:
Erikleonard (02-04-2023),
Erikleonard (02-10-2023)
Helicoil in place is probably possible but the issue would be drilling the hole out to right size for the heilcoil, difficult without a right angle drill. You did not mention but I assume this happened because you replaced the pump? Hopefully you left that stupid stud (#12) off when you went back (I never put them back on)? If you did it is only about 20 mins to get the pump off.
Brandon318
06-25-2022 06:26 PM
