Power steering question
I have a 1998 D1 and was doing a power steering flush. Does the power steering fluid circulate through the ps pump when you remove the wire/plastic filter from the reservoir? I pulled it out to gain better access to use a hand pump to pull the fluid out but the fluid did not appear to replenish as fast compared to when the filter was in the reservoir?
That explains it. I put maxlife atf in it with no lucas since some say lucas can swell the seals too much. Don't want to cause more of a problem than what I have (small leak and slight steering vibration/noise coming through steering wheel when I turn to the right when vehicle is stopped)
johnnyjohnny
09-26-2019 09:37 PM
DiscoBritney
12-19-2011 06:24 PM
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
