Power steering question
Old Feb 23, 2010 | 08:36 PM
bantham1's Avatar
Default Power steering question
I have a 1998 D1 and was doing a power steering flush. Does the power steering fluid circulate through the ps pump when you remove the wire/plastic filter from the reservoir? I pulled it out to gain better access to use a hand pump to pull the fluid out but the fluid did not appear to replenish as fast compared to when the filter was in the reservoir?
Old Feb 24, 2010 | 08:40 AM
okdiscoguy's Avatar
Not sure what you are asking, but the screen is just a filter. It takes a bit to get through it. ie- if you fill while it is out, it fills quickly. If you fill with it in, it takes a second for the level to even out and you will have to add again.
Old Feb 24, 2010 | 02:54 PM
bantham1's Avatar
That explains it. I put maxlife atf in it with no lucas since some say lucas can swell the seals too much. Don't want to cause more of a problem than what I have (small leak and slight steering vibration/noise coming through steering wheel when I turn to the right when vehicle is stopped)
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
