power steering reservoir cap
Old Feb 10, 2013 | 05:51 PM
dougn's Avatar
Default power steering reservoir cap
my power steering cap leaks. i wonder if i'm missing a gasket or o ring. can someone verify if theres any......
Old Feb 10, 2013 | 06:35 PM
It will leak if the system is over filled, its supposed to do that to prevent over pressurization and blowing a seal or a hose.
Old Feb 11, 2013 | 02:28 PM
CANAMDiscovery's Avatar
Same kind of issue... both my ACE and power steering reservoir caps have a very subtle amount of fluid leaking. I was going to start looking for new seal or caps.
Good to know the cap allows a little pressurized fluid to release.
Piece of mind.
Old Feb 12, 2013 | 07:18 AM
dougn's Avatar
the fluid shouldnt be under any pressure. it just churns around in there as it gets pumped back into the reservoir
Old Feb 12, 2013 | 07:28 AM
If overfilled it would have pressure, it needs the expansion space.
Old Jun 16, 2019 | 04:09 PM
Discorama's Avatar
I had a minor leak, the reservoir always got a slight oil film on it. Took out the O-ring from the cap and inspected it. Looked OK, but the cross section was only 3mm horizontally, while 3.5mm vertically. Looked up the standard sizes and found an O-ring that exactly fits: AS-209 (AS568 SAE). Went to my local hardware store and found it for $0.69:
The cross section on the package is not accurate, it's measured 0.139", not 0.125", but which is exactly standard size. Now the cap sits really tight in the reservoir. The two O-rings compared (left = new, right = old) shows clearly the difference:
JUKE179r
Dec 16, 2018 07:06 AM
jayj
Dec 19, 2012 05:14 PM
RHD 4 LIFE
Dec 1, 2012 05:48 PM
morg59jeep
Apr 14, 2011 11:07 PM
Classklown90
May 3, 2010 08:47 AM
