Power steering resevoir/return line
Old May 16, 2009 | 02:00 PM
nickd503's Avatar
Default Power steering resevoir/return line
So I've got a pretty nasty leak on the hose coming from my power steering fluid tank (the non pressurised one with silver squeeze clamps). I was thinking of replacing the hose myself and was wondering if I could get by without ordering the exact same hose. A friened informed me that I should be able to just buy some similar black hosing with the same I.D/O.D and secure it with regular silver hose clamps seeing that it's not a pressurised line....anyone swap one of these out before? I'm sure it could get a little messy with the remaining fluid in the hose...any info would help
Old May 16, 2009 | 02:30 PM
Yes you can use a none Rover hose with 2 new clamps. Be ready to flush the system using 3 quarts of power steering fluid, a bottle of Lucas power steering additive and some sort of a hand pump.
Shout if you have any questions.
Old May 16, 2009 | 02:33 PM
nickd503's Avatar
how would i go about flushing the whole power steering system? I was under the impression i could just swap out the hose and fill the resevoir back to it's full level.
Old May 16, 2009 | 02:50 PM
okdiscoguy's Avatar
If the hose isn't rotted, might just try new clamps first. Those squeeze clamps are junk.
I just empty the reservoir and fill with new fluid 3 times while driving in between. Mike have a better way.
Old May 16, 2009 | 04:23 PM
I just fill the bottle, start the engine, turning the steering wheel both ways all the way to the stops, turne the engine off, remove the old fluid and do it 2 more times, using the Lucas the last time as part of the refill.
Old May 16, 2009 | 05:18 PM
nickd503's Avatar
thanks mike! so I take it there is a plug on the power steering unit itself to drain all the fluid. Im gonna give this a try
CANAMDiscovery
Apr 24, 2012 07:19 AM
LD420
Feb 25, 2011 06:59 AM
Boats121
Jul 24, 2010 11:59 AM
krazzz
Oct 6, 2009 08:04 AM
SpeedAgent
Mar 24, 2008 03:56 PM
