Brake Fluid resevoir
Old Mar 24, 2008 | 02:18 PM
SpeedAgent's Avatar
Default Brake Fluid resevoir
Does anyone have a picture of a DII brake fluid resevoir? I have a 2002 and apparently mine is different than most and I can't find a cap for my pressure bleeder. I find that just as weird as the pressure bleeder company. Can anyone posta picture under the hood so I can get a good look at the fluid res.?
Mine is square and the opening is about 1 3/4" in diameter. They apparently don't have any caps this size and the universal fit cap doesn't extend out far enough for the j-bolts to go down on the sides. What a pain.
thanks,
Chris
Old Mar 24, 2008 | 03:40 PM
Default RE: Brake Fluid resevoir
Why not just have you and a friend do a 15 minute bleed and save the money?
Old Mar 24, 2008 | 03:56 PM
SpeedAgent's Avatar
I already have the bleeder, just need the adapter. I like doing my own work andI don't like doing the pedal flush process. I have a theory that it loosens brake seals over time with all of the undue pressure, but that's just me. The pressure bleed takes 10 minutes and is very easy.
Chris
JPSpen
Mar 4, 2013 07:53 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
CANAMDiscovery
Apr 2, 2012 12:38 PM
krazzz
Oct 6, 2009 08:04 AM
nickd503
May 16, 2009 05:18 PM
