Power steering whine after head gasket change?
I got my cylinder head gaskets changed yesterday per my last problem with the engine running rough. It now runs much better, but there is a loud whining (worse when turning the steering). I assume they had to drain/refill the power steering fluid for the cylinder head change, since they are claiming that the noise is due to 'air in the system' that will 'work itself out in a day or two'. Has anyone see/hear of such a thing or did they break something on reassembly?
on
Are you sure they drained the p/s system, how much have you driven it since the engine work?
Is it a growling sound, have you checked the p/s fluid level?
Yes this can happen, make sure the p/s reservor is full and with the engine running, turn the steering wheel full left and right 4 or 5 time and see if it starts to quiet down afterwards. If it doesn't, get it right back to the shop so you don't burn up your pump.
johnnyjohnny
09-26-2019 09:37 PM
Freebie_Oslo
Freelander
06-17-2013 02:48 PM
