Power Window auto-down function
So this morning my daughter rolled down the driver's side window and then it wouldn't come back up which would indicate a stripped gear or bad regulator. After pulling the door panel off and playing around with it, it appears to still function. I can make it go up and down. The problem is that the auto-down feature doesn't know when to stop. It just keeps going until it gets stuck. Is there a way to just disable the auto feature on the front 2 windows?
The following 2 users liked this post by Harvlr:
JoshD (10-08-2022),
longtallsally (10-08-2022)
What I observed is the regulator went down to the last gear tooth and got stuck there. Solved in a not pretty way; by putting a ~1 litre capped soda plastic bottle at the bottom of the door guts. It works as a soft stop, never reaches the last regulator gear tooth where it binds and it has been there 4 years with no problems.
