Pressure Test - Leaky Valve?
Old Jun 22, 2021 | 11:46 AM
humroot's Avatar
Default Pressure Test - Leaky Valve?
Hi all. I'm chasing a p0305 and p0300.
New Plugs
New Wires
New Coils
Cleaned and rebuilt injectors
I just did a compression test on #5 and it is really low at 50. I had all plugs removed and my foot on the accelerator whilst checking. I put a plug in #3, no difference. Put a plug in #7, no difference. Added oil to #5, no difference. So am I looking at a sticky valve? Any options other then removing the heads for a valve job?
Thanks,
Jamie
Old Jul 4, 2021 | 01:21 PM
humroot's Avatar
Default Could use help with cylinder pressure loss
So pulled the valve cover and the rocker shaft. I removed the plug from 5 and used compressed air to check for leaks. There is air leaking somewhere...i can hear and feel it come up through the holes where the lifters are. If I do the same for cylinder 1, no leaks at all. I pulled the springs for cylinder 5, and they were smooth and sealed up when I blew air through the cylinder, but it is still leaking somewhere when I did this.
So now I am stuck. I'm fearing bad rings or bad head gasket - even though the hg is pretty new and i used studs instead of stretch bolts. Is there anything else that could leak in cylinder 5? PVC or something?
Would love some thoughts before I have to dig into this engine...again.
Thanks.
Jamie
Old Jul 5, 2021 | 12:18 PM
tnrangerover's Avatar
I'm not sure the reason for low compression, so I'll spare any bad advice, but on my last D2, P0300 (random or two or more cylinders misfiring) was a bad injector o-ring. you're not much further away from checking that as well. With low compression though, I think you'll have to get much further into the engine to figure out the issue. did it overheat recently? does it burn a lot of oil? does it make a tapping noise when warm but not when cold? does it blow white smoke out the exhaust?
Old Jul 5, 2021 | 02:36 PM
Richard Gallant's Avatar
So you hear air so far nothing to panic about, did you do a dry then wet compression test. That is the 1st way you check for ring failure, but at 50 unlikely to be a ring though possible.
The most likely culprits are valves, valve seals, injector seals. You can use dishwater soap & water mix to test both - you get bubbles if you have an air leak.
Fast951
Sep 26, 2019 09:15 PM
abran
Jan 3, 2014 11:09 AM
huntercreation
Oct 17, 2011 09:44 AM
benflynn
May 12, 2009 10:12 AM
BURover
Aug 30, 2006 03:06 PM
