Pressurized cooling system
Old Jul 11, 2023 | 12:53 PM
Richard Gallant's Avatar
@DiscoMerlin Hopefully it is just the head gasket and not cracked cylinder.
Old Jul 11, 2023 | 02:59 PM
DiscoMerlin's Avatar
Have you ever seen temps rise that quickly? I am inclined to believe that either a liner has slipped or the block is cracked. Anyway, I have put so much into the rest of the truck that I will probably do a new long block and call it a day. That way I can tear this one down and really go through it in the fall/winter.
Old Jul 11, 2023 | 07:57 PM
Extinct's Avatar
Originally Posted by DiscoMerlin
Thank you all for the comments. I think that I may be safe to conclude that I have a blown hg. New water pump flowing nicely, new thermostat, new cap, new hoses, new viscous clutch/ fan. No air in system. Fresh coolant 50/50 mix. 10 minutes of driving from cold, temps fine at first with heat on full blast. Then temps started rising, and rising. Hit 260 before I could get it off the road. 199-265 in less than 60 seconds. Coolant boiling and hoses and expansion tank look like they are going to explode. Coolant changed colors.
Could be a blown hg but usually that rate of temp increase is related to stuck thermostat. inline stat? If so remove the element and test. Also run with the reservoir cap one full turn loose from full tight and it will not build pressure. Slip a hose over the overflow tube and run it up to the cowl area so it doesn't dribble.
Old Jul 11, 2023 | 08:08 PM
mln01's Avatar
What did you observe to determine the system was "overpressurized"? And did the temp spike happen immediately after you did all the other cooling system work?
I know that when I drain, flush, refill and bleed the cooling system every couple years the UltraGauge will initially show a spike to ~230° when I take the truck for a spin, but the temp also drops back pretty quickly (after a minute or so, I recall). Is it possible that's what happened in your case, and that you perhaps overreacted to a quick spike?
I agree with what others have said that if there's no coolant loss it's likely not a failed headgasket or cracked block. My money is on a failed thermostat (stuck closed), or on what I described above.
I'd try what Extinct suggested and try driving it a few miles with the cap fitted loosely (although that shouldn't be necessary with a well-maintained system).
Old Jul 11, 2023 | 09:27 PM
Default Overheating quickly
I just thought that I would try again after refilling with the coolant that boiled over after the overheating 8 hours ago. Temps spiked again at idle. This time I left the cap loose.
Old Jul 11, 2023 | 11:04 PM
Cooling system is essentially new except for the heater core. Previous gray OEM Thermostat was 2 months old. Today it happened on a brand new thermostat installed today. OEM gray again. It does act like a stuck thermostat but what are the odds of getting 2 bad ones?
Old Jul 11, 2023 | 11:18 PM
Harvlr's Avatar
The odds are high enough.
Old Jul 12, 2023 | 04:50 AM
Extinct's Avatar
Super high. Now you know why I have two brand new ones on the shelf I have been offering to give away to anyone who will pay shipping. Experience like you are having is exactly why I converted to inline.
mln01
May 1, 2016 09:49 AM
kufkuf
Jan 16, 2016 10:00 AM
bbeismann
Feb 1, 2013 10:22 AM
Infrno
Mar 22, 2012 10:41 PM
Chicago KC
Mar 21, 2012 07:07 AM
