Problem with Climate Control and clock
Old Jun 12, 2021 | 10:13 AM
Chris Gregson's Avatar
Default Problem with Climate Control and clock
Morning all, need to start digging into a problem today. Recently, my climate control won't remember where I had it set when I last shut off the truck. When I start the truck it will be off, when it turn it on it will have defaulted back to C, but it works fine (until I turn the truck off again). The clock is also affected, and just shows a solid green glow, with odd black streaks where it seems it's trying to "paint" Any starting ideas? Fuses and wires? Thanks in advance!!!!
Old Jun 12, 2021 | 11:47 AM
Found it to be fuse 20, replaced, but then blew again 30 seconds later. I had 30 seconds of everything working
Old Jun 12, 2021 | 12:11 PM
tnrangerover's Avatar
you have a short somewhere or potentially corrosion. You could buy a used climate control unit and see if that fixes it, or trace the wires back to the fuse box and see if any wires have worn through. You’ll probably have to remove the radio and such as well to see back there
Old Jun 12, 2021 | 12:16 PM
Thanks tnrangerover, so just focus on the write from the driver's side Fuse box to the radio? Not before that (i.e. don't focus on drivers side fuse box to main fuse box?) This is very helpful since I already have the radio out.
Anthony Frantzis
Dec 22, 2018 04:18 PM
gulfstream69xr7
May 3, 2017 07:27 AM
mx468
Dec 11, 2016 10:59 PM
showbet
Sights N Sounds
Mar 7, 2009 07:36 PM
