problem removing head bolts
the strange thing is the driver side head bolts were easier to get loose. the passenger side every bolt has been fighting me. makes me think its been done before. it was the passenger side that was leaking.
also do you really have to replace both gaskets or just the one. i know it probly better to replace both im just currious.
On mine, with a HG leak out the side near dip stick, that head was easy to get off. Other side was more stubborn. Machine shop said overheating will loosen bolts.
Would advise do both gaskets. And take heads for check and/or machining. One guy recently did a great HG job, had almost immediate leaks, found out that heads were .004 inch when he tore it down second time and took to the shop. For reference, printer paper is about .0038 inch. Flatness spec is .002 inch.
see pictures of how I did it.
The shop before me pounded in the firewall.
So, that helped too.
Flickr: Landroverdude2's Photostream
Find a shop you can trust, and they will usually have a hot tank that will make them look like new. Don't skip having them checked for flatness. Only a spec of 2/1000ths. That is half of the thickness of your printer paper. Shop will also do the valve seals with parts from your kit.
Here is a pix of mine before and after.
![](https://landroverforums.com/forum/attachments/discovery-i-39/16652d1371055715-head-gasket-shade-tree-way-p1130047-jpg)
