Problem sunroofs!
Old Jan 8, 2008 | 08:09 AM
minimad666's Avatar
3rd Gear
Default Problem sunroofs!
Both of the sunroofs on my 99 TD5 have stopped working! Ive checked the current at the switches for both roofs with an ammeter, and there is current flowing, but there is still no movement from either of the roofs. Just wanted to know if this is a common problem, and if anyone has any suggestions as to what it could be and what I can do to fix it!?! Thankyou!
Old Jan 8, 2008 | 08:43 AM
Default RE: Problem sunroofs!
So how often do you clean and lube the tracks and arms???
No maintance and they will fail.
Old Jan 8, 2008 | 08:56 AM
raid13's Avatar
ok, so both your sunroofs have stoped working at the same time?
when i hear this i think sunroof ecu but you say that
you have battery power at the motors, can you feel them move
a little when you use them like there bound up?
Old Jan 8, 2008 | 09:10 AM
minimad666's Avatar
3rd Gear
When the switches are depressed, no movement can be felt in sunroofs, but the switches do make a clicking sound as if the roofs are trying to activate. Also there is very bad water ingress from both roofs, could this have affected the motors, or the switches themselves? Is there a quick check for this? Can the sunroofs be opened manually, if so how? Thankyou!
Old Jan 8, 2008 | 09:36 AM
ajh's Avatar
ajh
Take every connector apart, remove the motors, dry everything. This is always step 1 when you suspect water. When you re-assemble lube everything, put di-electric silicone grease in every connector and wherever you suspect water might get at electronics. This goes for every connection on the entire vehicle, every header, every plug, every headlight, etc... corrosion will kill these trucks slowly if you let it, and it always shows up as intermittant or hellish to diagnose problems.
Old Jan 8, 2008 | 10:54 AM
Yes, there is a small rectangular access plate in frony of the sun roof, that when removed you can use an allen wrech to manually open and close the sun roof.
Old Jan 12, 2008 | 09:10 AM
minimad666's Avatar
3rd Gear
Managed to manually open both of the roofs, and got the front roof working fine again. Covered the rails in greese and sprayed penetrating oil on to the cables coming from the motor. The rear sunroof is still very stiff and is very hard to open manually. Is there any other way to losen up the rear sunroof, as the motor can be heard trying to operate, but due to the resistance the motor encounters, it automatically shuts-off!
Old Jan 12, 2008 | 09:33 AM
You are boarder line in trouble with the rear roof. The only thing you might try is to have someone work the switch while at the same time you try and help move it. This could work, and it can also completely die, if so, go to , http://www.roverlandparts.com/index....S&Category=373 for a good price on a used, guaranteed replacement sun roof.
Old Jun 10, 2012 | 10:05 AM
Turtlep's Avatar
5th Gear
How do I test the ecu to make sure it is working to see if it is sending signal to motors to open and close
malmberg
Feb 24, 2009 01:40 PM
spence426
Oct 24, 2008 11:15 PM
fortworthcoe
Jun 2, 2008 05:47 PM
sailorcolin
Apr 9, 2008 07:16 PM
johnkbl
Apr 16, 2007 02:39 PM
