Problems with Atlantic British HUBs?
Old Mar 28, 2015 | 08:37 PM
94svt50's Avatar
Default Problems with Atlantic British HUBs?
Im in the process of changing rear rotors and brake pads and I discovered I have had a leak from the right rear hub. The pads and caliper are pretty gummed up so it looks as if it has been on going for some time. I replaced the hub back in the summer of 2012 with a brittpart one from Atlantic British. After I installed it it began leaking again after about 100 miles and was warrantied by AB. Both times I replaced the O ring. Are these Hubs just junk? Now its been 2 years and maybe 15k miles and its leaking like a sieve, I would think a $400 part would be a bit better. I cant 100% rule out O ring but it looked dry around outside of O ring when I pulled hub but, with gear oil gunk all over place I cant really pinpoint. Has others had such constant leaks from the hub? Am I missing something here? I did check diff vent and it was clear any other thoughts?
Thanks
Old Mar 28, 2015 | 08:57 PM
ZGPhoto's Avatar
I'd be looking at the o ring before the hub. The hubs aren't filled with oil, the axles are
Old Mar 28, 2015 | 09:10 PM
94svt50's Avatar
But the seal around the bearing in the hub can fail then you end up with gear oil washing out the bearing grease. Does RN sell oem O rings? Both times I changed O rings I used the aftermarket ones from AB
Old Mar 29, 2015 | 10:02 AM
ZGPhoto's Avatar
I've heard in the past the aftermarket ones aren't the correct size, as well as the axle seals in the front. We do have the genuine o-ring for $3 or so
Old Mar 29, 2015 | 11:10 AM
Racer X's Avatar
Make sure that the axle bore is rust and corrosion free before installing the new hub seal, or a leak will result.
Old Mar 29, 2015 | 11:18 AM
94svt50's Avatar
Thanks for the replys. Ill go on and order a o ring from RN website. Its a bit cheaper then a new hub.
Old May 14, 2015 | 06:50 PM
Merlin390's Avatar
Mine leaked as well till I tightened it to the 350 ft lbs.
s10lowrider1994
Sep 29, 2011 03:08 PM
jmt
Dec 12, 2008 06:59 PM
Philhowe
Nov 3, 2008 09:12 AM
dkeach
Jan 29, 2008 12:33 PM
SpeedAgent
Aug 17, 2007 07:18 AM
