problems that freeze you
Old Nov 5, 2007 | 08:40 PM
EL GALLO's Avatar
Default problems that freeze you
Hello
I have a friend that called me today to have me ask about a problem he has on his 97 disco.I t seems he has leaking freeze plugs and his mechanic told him he has to remove the engine to replace them.Is this true? I have known others whereengines are not necessary to be pulled to change them.I believe they are the side freeze plugs not the ones between the trans.Thanks always.
Old Nov 6, 2007 | 07:31 AM
Default RE: problems that freeze you
I would power scrub the engine, don't get the ECU wet, and then check each plug. Might find that it has leaking head gaskets, freeze plugs are not a common issue with Rovers.
Old Nov 6, 2007 | 08:20 AM
EL GALLO's Avatar
If it isthe head gaskets leaking should he replace them or can he use it for some time until theinevitable? ,truck has 123000 miles on it.As always thank you very much.
Old Nov 6, 2007 | 08:32 AM
They should be changed out before the engine over heats and drops a sleeve, them he would be looking at a new engine.
Old Nov 6, 2007 | 01:55 PM
EL GALLO's Avatar
ouch!I will inform him.Thanks.
Old Nov 7, 2007 | 08:05 PM
ajh's Avatar
ajh
Or just replace them with a block heater, they don't tell you to remove the engine to put one of those in.
calebbo
Oct 12, 2011 09:54 PM
mtfife
Mar 9, 2011 07:57 AM
ggushee
Nov 21, 2007 03:47 PM
ggushee
Jun 17, 2007 10:47 AM
37chambers
Aug 22, 2005 10:40 PM
