Prop shaft replacement
Just received my prop shaft from GBR and was going to still it here in a few minutes. Just a quick question about alignment. In the rave it says that it needs to be marked if it's going to be retrofitted. When I install the new shaft is there any alignment to be done. I was assured by GBR that the shaft had been balanced and was assuming it was a straight swap.
Any help would be appreciated.
Alex_M
Sep 7, 2024 05:21 PM
aaveryy
May 12, 2007 07:51 AM
