Prop shaft replacement
Old Mar 8, 2011 | 03:37 AM
raul507's Avatar
Default Prop shaft replacement
Just received my prop shaft from GBR and was going to still it here in a few minutes. Just a quick question about alignment. In the rave it says that it needs to be marked if it's going to be retrofitted. When I install the new shaft is there any alignment to be done. I was assured by GBR that the shaft had been balanced and was assuming it was a straight swap.
Any help would be appreciated.
Old Mar 8, 2011 | 06:03 AM
Bundu's Avatar
Banned
Just install it. Take note that the bolts on the transfer case side are not evenly spaced.
Old Mar 8, 2011 | 12:06 PM
raul507's Avatar
Done and done. Man, huge weight of my shoulders knowing that's done.
Old Oct 13, 2011 | 10:42 AM
moncton_vw's Avatar
I just received my Tom Woods front prop shaft... should I re-use the same bolts if they come off in good shape?
Any other tips or things to do for this procedure?
Old Oct 13, 2011 | 10:53 AM
Good time to examine and clean/tighten any starter wiring....
Old Oct 13, 2011 | 11:40 AM
drowssap's Avatar
use the same bolts but use new nylock nuts, those nylock nuts have a one time use.
once you thread something thru the nylon on the end of the nut it no longer works as a lock.
Alex_M
Sep 7, 2024 05:21 PM
hankeester
Feb 14, 2014 09:58 AM
jw928
Feb 28, 2009 10:26 PM
tomfraser
Jan 23, 2009 01:59 PM
aaveryy
May 12, 2007 07:51 AM
