prop shaft seal removal
Old Nov 5, 2021 | 05:38 PM
me 2's Avatar
Default prop shaft seal removal
Is there a special way to remove the rear prop shaft seal or just beat it out?
Old Nov 5, 2021 | 11:25 PM
I Brake For Cats's Avatar
If you're talking about the rear pinion seal, a seal puller will be your friend. It will render the old seal unusable to be ready with a fresh one.
Old Nov 8, 2021 | 11:21 AM
Brandon318's Avatar
You also need a special tool to remove the flange. Or have you already gotten the flange off?
Old Nov 8, 2021 | 12:50 PM
me 2's Avatar
Thanks guys. I was a day late to see this. Beat the @#$% out of the seal without hurting the shaft and it finally came out. Which part is the flange? I replaced the flex joint, seal and U joint.
humroot
Aug 13, 2020 04:00 PM
frostythor
May 5, 2020 02:12 PM
me6067
Dec 11, 2017 09:50 AM
nuclearw
Jul 29, 2013 09:54 PM
twaszak
Jun 4, 2011 09:01 AM
