Propeller shaft coupling for 1996 discoII just 80k miles HELP!
Old 01-14-2011 | 07:27 PM
jenniemcl's Avatar
Default Propeller shaft coupling for 1996 discoII just 80k miles HELP!
New here - HI, Found super 1996 SE 1&1/2 years ago under 80k (was garage kept by church lady) Love it..Had mechanic ck it out June 2009 & couple oil changes since..
Last month Oil change guy who says worked @ LR dealer said Propeller shaft coupling was worn & needed relacement. He said would feel vibration & then K-PUT, car would just not work.
Not feeling any vibration & car works great..should I be paranoid? What signs should I look for THANKS
Old 01-14-2011 | 09:47 PM
antichrist's Avatar
Welcome.
It's the rubber rotoflex on the rear propshaft at the diff. Look for cracking and/or shredding.
Give rovafarm a call.
http://www.rovahfarm.com/DiscoIAxles.htm
Trevor sells several different brands and is honest if you ask which he suggests buying.
Old 01-15-2011 | 08:10 AM
Try again, what year is the truck and was he referring to the front or rear drive shaft?
kid A
07-05-2015 04:33 PM
Waltmink1
03-13-2013 10:09 AM
mcgyver210
01-30-2011 10:03 PM
imike1007
07-20-2010 07:44 PM
Petron
11-10-2008 07:14 PM
