Propeller shaft coupling for 1996 discoII just 80k miles HELP!
Old Jan 14, 2011 | 06:27 PM
jenniemcl's Avatar
Default Propeller shaft coupling for 1996 discoII just 80k miles HELP!
New here - HI, Found super 1996 SE 1&1/2 years ago under 80k (was garage kept by church lady) Love it..Had mechanic ck it out June 2009 & couple oil changes since..
Last month Oil change guy who says worked @ LR dealer said Propeller shaft coupling was worn & needed relacement. He said would feel vibration & then K-PUT, car would just not work.
Not feeling any vibration & car works great..should I be paranoid? What signs should I look for THANKS
Old Jan 14, 2011 | 08:47 PM
antichrist's Avatar
Welcome.
It's the rubber rotoflex on the rear propshaft at the diff. Look for cracking and/or shredding.
Give rovafarm a call.
http://www.rovahfarm.com/DiscoIAxles.htm
Trevor sells several different brands and is honest if you ask which he suggests buying.
Old Jan 15, 2011 | 07:10 AM
Try again, what year is the truck and was he referring to the front or rear drive shaft?
kid A
Jul 5, 2015 03:33 PM
Waltmink1
Mar 13, 2013 09:09 AM
mcgyver210
Jan 30, 2011 09:03 PM
imike1007
Jul 20, 2010 06:44 PM
Petron
Nov 10, 2008 06:14 PM
